It is currently Fri Jan 02, 2026 8:02 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Tue Jul 02, 2013 11:41 pm
Car Model: 1964 Valiant V200
Available cheaper as AGS Nicopp line. But the black AGS stuff is just as easy to bend, though not as resistant to corrosion.
PostPosted: Thu Jul 18, 2013 8:57 am
Wow, what a blast from the past.
My lines kinked while workign with them. I bent steel tube from the trans ports to about the bellhousing. Then used rubber hose from there to attach to the original sections of undamaged tube. Ran like that for years. With the recent engine and radiator swaps I decided to finally go to the AN stuff - left the parts of tube I bent myself then ran AN from there to the rad.
It's the cat's meow, looks pretty good. Used it for the efi gas lines too.
