It is currently Tue Nov 24, 2026 12:21 pm
 Post subject: Checking float etc
PostPosted: Sun Jul 21, 2013 9:22 am
OK fixed my vacuum advance issue.Dont have a
carb rebuild kit and need to go thru this holley 1920
that I got from summit and find out why its cutting out
on acceleration at any speed.The manual says accelerator pump
and float.Whats the easiest way to check the float level ?
Since I bought my 63 my guitar
has taken the back seat.
 Post subject: Couple of items
PostPosted: Sun Jul 21, 2013 9:48 am
1) Remove float and put in container of gas and see if it still floats.
2) Install in carb and check using ruler per FSM.
3) No ruler, FSM? Quick and dirty way on Holley, flip it upside-down and
make sure the flat part of the float is even with the top of the bowl...
Most likely the problem is the Acc. pump.
PostPosted: Sun Jul 21, 2013 12:36 pm
Thanks cause tearing into carbs is a dark area for me.
Not only that but the diagram shows parts on the Acc pump
that these carbs I torn into dont have them, like the push rod
sleeve ,spring ,and bearing.The service manual did me right
for the wiring but guess I should check into the modificactions
on some components. Thanks again D cause I just moved to
Modesto Ca and these people drive crazy and look at me like
get that heap off the road..I tell you I get no respect.
PostPosted: Sun Jul 21, 2013 12:39 pm
