It is currently Fri Jul 17, 2026 6:34 pm
 Post subject: K Frame Weight
PostPosted: Wed Jul 24, 2013 4:42 pm
Hello Slanters,
Does anyone know the Weight of a 67-72 A body K frame? Any engine configuration would be fine. I am looking for the weight without any mounts, rods, bushings etc. attached
I have an earlyk frame from a 60-66 A Body and I weighed in at 28.4#..
I imagine the 67-72 models would be heavier..
Thanks for any info.
PostPosted: Thu Jul 25, 2013 12:01 am
The late one is probably not a whole lot heavier, but if you look it over there is about 10 pounds you can cut off fairly easily.
PostPosted: Thu Jul 25, 2013 4:09 am
Just don't go TOO far with the cutting... Rightt Dennis? :shock: :lol:
PostPosted: Thu Jul 25, 2013 11:03 am
Actually that one I gave you needs welded around the flange and it's good to go.
