It is currently Fri Nov 20, 2026 4:21 am
 Post subject: Milled Head
PostPosted: Sun Jul 28, 2013 6:25 pm
Just wondering. I know since I have owned the car, that the head has been milled .93. However, I have no idea what was milled before I got the head. But if we assume it is about .95 or so, what would the approximate compression ratio be on that? Could it be 9.5:1 or higher?
 Post subject: Insufficient data...
PostPosted: Sun Jul 28, 2013 6:30 pm
.093 cut doesn't give us a real starting point...
How far are the pistons in the bore at TDC?
Shim or Composite head gasket.
What year head? (If it's a 1963 head, a .100 cut might just put you at 8.2:1 if it started with a 68cc chamber...)
Stock bores right/no overbore?
PostPosted: Mon Jul 29, 2013 4:54 am
The pistons are bored .040 over. I haven't pulled off the head yet, to get that measurement inside the cylinder wall. I am not exactly sure what year head I have on there, but I do know it is not a 63. As I went to get a new water temp sensor, the new one I got was too large. I had to ask for a 71 model truck to get the one I needed. But what it actually came out of, I have no real clue. But I do know the last time I had the head milled, the guy told me it might be the last. He thought it was getting too close to not getting milled again.
I have this rattle, and decided just to pull the engine, and take care of all the leaks (oil pan, rear main seal, front tranny seal).
Once I get that engine out, I can give better data. Thanks.
PostPosted: Mon Sep 02, 2013 7:06 pm
http://www.foundationpc.com/press/press66d.html
Anybody knows about Dick Maxwell. He wrote up that press thing, and according to him, .090 changes it 8 to 9.5. I have a head from 67-74, and I believe it started at 8.4 to 1. Meaning I could be in between 9.5 to 10.
But you know you can't believe everything on the net. But he had Staff Engineer next to his name.
PostPosted: Tue Sep 03, 2013 4:40 pm
Lots of variables as deck height comes into play. I wonder if a 198 VS a 225 VS 170 would vary? I didn't measure my pistons down in the hole. I took .090 off my head. Polished and unshrouded with stock valves.
I have a 74 head all stock in the chambers. It CC'd at 45 with .060 off.
PostPosted: Tue Sep 03, 2013 5:16 pm
... I wonder if a 198 VS a 225 VS 170 would vary?
Deck height is different for all 3 engine sizes and vary a lot...
Example: I have checked many 225's and seen decks at -.140 and up to -.210, as well as in-between. (-.180 is pretty common)
In the end... take your measurments and "do the math" to get the DCR number you want. (target 8.0 DCR for regular pump gas)
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
