It is currently Fri Jul 17, 2026 12:49 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
 Post subject: Close but no cigar
PostPosted: Tue Jul 30, 2013 9:36 pm
Went to TnT, tonight. Been trying to get my Cuda into the 12's, and over 100 mph, in the 1/4 mile. It has gone over 100 a couple of times, but never 12's. Tonight, was best ever, Et's and MPH, and the air was terrible.
60ft.....................1/8...........mph...........1/4.............mph
1.828................8.264........81.61.........13.096.........100.95
1.764.................8.218.......80.57.........13.093.........100.47
1.770.................8.182........81.50........13.009.........101.15
1.776.................8.219........81.03........13.064.........101.02
Just for giggles and grins my 1st pass was on motor only.
2.755.................11.791......60.32..........18.333.........74.54
All bottle, no throttle. :lol: :lol: :lol: :lol:
PostPosted: Tue Jul 30, 2013 11:22 pm
Congrats on some good passes Charlie.
PostPosted: Wed Jul 31, 2013 5:02 am
Impressive stuff, Charlie! So close to the 12s. If it makes you feel better my 68 turbo Dart has run over 100 MPH and only low-mid 14s ETs... Need to work on that...
PostPosted: Wed Jul 31, 2013 5:59 am
Looks like wheelspin killed the 60 on that 'throttle' pass, eh? :lol:
You just can't tame that beast!
Next time, one less cheeseburger ought to get you there!
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Wed Jul 31, 2013 10:23 am
Even though, I didn't get into the 12's, I was happy. Every run over 100 mph, and the most consistant the car has ever been. Only .087 difference fastest to slowest. Plus the fact of how many people came over to check the car out. I do need to check out the engine or converter, as I am down about 300 rpm full stall on motor.
PostPosted: Wed Jul 31, 2013 3:13 pm
I found two more time slips, that fell under the seat. They are 1st and 2nd bottle runs. Spun on the 1st run, so lowered tire pressure for the remaining runs.
1.846.................8.387.......81.47.........13.216.........101.23
1.822.................8.287.......81.94.........13.090.........101.68
 Post subject: Aha!
PostPosted: Wed Jul 31, 2013 4:01 pm
Well the weight of the paper under the seat is what cost you that .009 to dip under the 13 mark... :roll:
I feel for ya! Anything else in the car that you can lighten to get you that extra hair to beat the mark?
:wink:
 Post subject: Re: Aha!
PostPosted: Thu Aug 01, 2013 5:26 am
:wink:
There is a lot I can remove to save weight. The problem is, the car is basically too good to "butcher". It was just going to be a tempory race car, back in 2001, when I started racing it. It is really too heavy at 3250 lbs. I have enough other cars, that I don't mind putting on a diet. I really need to find a good home for this 66 Cuda, but there is not a large market for something like this. I will probably pull the slant six drivetrain during the winter, and install either: a correct date coded 273 engine, or a 318 cop car engine, and put it up for sale. Unless I can find a buyer as it is.
PostPosted: Thu Aug 01, 2013 7:11 am
yes agrees with charlie that cuda way to nice to chop weight from
PostPosted: Thu Aug 01, 2013 7:35 am
Don't feel too bad Charlie, my pig went 12.002 and 12.001 in my quest for the 11's. :cry: :lol: :lol:
PostPosted: Thu Aug 01, 2013 9:06 am
Hell, I don't feel bad, at all. I'm happy as a pigi n s--t, it runs that good, with the small amout of money I have in the motor, and pretty much stays together. I'm going to pull the plugs, look at them, look in the cylinders with a bore scope, do a leakdown test. If everything look good, I'll try one jet size bigger on fuel and nitrous.
PS: What are you doing online? Your'e supposed to be heading down here.
PostPosted: Thu Aug 01, 2013 9:21 am
Waiting for my travelling partner. Our flight leaves Midway at 5.
PostPosted: Thu Aug 01, 2013 11:41 am
.010 off (12.99) has me wondering how much fuel was in the gas tank, how much oil in the oil pan & trans pan... and maybe pulling the fan v-belt, right before the pass.
(you do have alturnator field shut-off... right?)
PostPosted: Thu Aug 01, 2013 2:04 pm
2-3 gal fuel, 5 qts oil and stock oil pan without baffles or tray. Deep trans pan. No fan belt, electric fan and water pump drive. Full throttle alt field cutout. Maybe I should swap the 7 1/4 rear back in :lol: . Actually, I think if the air hadn't been so "thick", I would have made it. It was upper 80 degrees, and driving through the pits, would get condensation on the outside of the windshield.
PostPosted: Thu Aug 01, 2013 2:14 pm
At airport.
