It is currently Sun May 24, 2026 5:14 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Aug 01, 2013 10:37 pm
Car Model: 62 Lancer, 63 D100
How is the full throttle Alternator field cut-out system put together?
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Fri Aug 02, 2013 4:34 am
I have a micro switch mounted on the carb. It actuates two relays. One relay is for the nitrous and fuel solenoids, the other relay is wired into the field wire between the regulator and the alternator. The relay uses the normally closed contacts. When the throttle goes wide open the imcro switch, triggers the relay, and the contacts open removing power to the alternator field circuit. This disables the alternator output, and the alt just acts like an idler pulley.
PostPosted: Fri Aug 02, 2013 7:38 am
Simple and elegant.
PostPosted: Fri Aug 02, 2013 5:22 pm
Nita and I really enjoyed hanging out with you and Peg today Charlie. :D
PostPosted: Fri Aug 02, 2013 7:32 pm
Thank you Charrlie, Very clear discription of a useful addition to my race cars.
Bruce
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Fri Aug 02, 2013 9:22 pm
We enjoyed it also, Glad you were able to stop by. Hope it is not another 6 or so years.
PostPosted: Sat Aug 03, 2013 4:57 am
The Slanted Family in person - priceless.
PostPosted: Sat Aug 03, 2013 11:56 am
Quoted for truth.
 Post subject: Bingo
PostPosted: Tue Aug 27, 2013 9:52 pm
Into the 12's. Got six runs in
1.767...........8.305.....79.95............13.215....99.74
1.771...........8.225.....81.45............13.056...101.04
1.768...........8.379......76.70...........13.64.......90.59 ran out of nitrous
1.724...........8.111......81.77...........12.921...101.48
1.745...........8.108......82.02...........12.905....101.64
1.738...........8.132......81.47...........13.055......97.39 lifted a little early, car got squirlly. Think I had a soft slick.
PostPosted: Wed Aug 28, 2013 3:14 am
12"s !!! Great news Charlie! Quite the accomplishment! :lol: :lol: :lol:
PostPosted: Wed Aug 28, 2013 5:01 am
Very strong, Charlie 8)
Not satisfied with a ninenine, goes right to a nineoh!
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Wed Aug 28, 2013 5:42 am
Schweeeeet. Congrats, Charlie!
PostPosted: Wed Aug 28, 2013 6:19 am
Congrats Charlie! :D :D :D :D :D
PostPosted: Wed Aug 28, 2013 9:22 am
Now, I need to check the plugs, and compression, again, and see if everything looks OK. Slicks were ok for air pressure. Guess I need to check all the suspension for wear/loose, and front end alignment.
PostPosted: Wed Aug 28, 2013 2:03 pm
Charlie,
When you saw the 12 second time slip was your smile as big as when you got the win at Mason Dixon?? :lol: :lol: I bet it was pretty close!
Rick
