It is currently Wed Nov 18, 2026 5:33 am
 Post subject: Shift lever o rings
PostPosted: Fri Aug 02, 2013 7:51 pm
My 1970 Dart tranny is leaking from the shift lever shaft (904 auto). Is it possible to replace the o ring without dropping the trans? Does anyone have the part number. Thanks
 Post subject: Timken
PostPosted: Fri Aug 02, 2013 7:57 pm
I think it's Timken 8609, typically in stock at Autozone for $8...
You can do the job in the car, but you will have to tilt the engine and tranny to get enough room to work on it. A few guy have a homemade specialty tool they work up to help remove and install it in the tight quarters under the floor pans.
Good Luck,
PostPosted: Fri Aug 02, 2013 10:23 pm
Is there a thread available that can guide me threw this? Thanks Duster
I don't always hotrod, but when I do, it has a six cylinder. Stay slanted, my friend.
PostPosted: Mon Aug 05, 2013 4:00 pm
Yah, you're in it and reading it right now! :lol:
OK, I'd like to see it too, anyone?
I'd probably drop the rear trans mount/xmember so I could lower the rear, certainly resulting in some unseen damage at firewall, then proceed to poke and pry at the seal with a hooked to of sorts, surely damaging the trans case and/or the shift shaft all the while bathing in stinky fluid, grease and other fun stuff... :oops: :wink:
1966 Coronet Deluxe
 Post subject: 904 seal
PostPosted: Tue Aug 06, 2013 6:52 am
Yea, I had tranny out while rebuilding engine. Replaced reverse switch and pan filter and gasket but couldn't figure out how seals were removed. After starting engine and driving car up and down driveway, it began to leak.
Users browsing this forum: Amazon [Bot] and 4 guests
