It is currently Sun Nov 22, 2026 10:06 pm
Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Jul 28, 2013 3:52 am
I open mine up evenly, and then start playing with I vs. E changes.
PostPosted: Tue Aug 06, 2013 11:06 am
So I decided last night to look at my cam card again and found something interesting. It says the valve clearance should be .015 (intake) and .017 (exhaust). This surprised the hell outta me because the specs state .015 and .020. My question is does that sound like the right settings to follow?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Tue Aug 06, 2013 1:10 pm
I just completed this onerous task for the first and second times. I had to redo my first attempt. My .02
I pull 6 of the 8 valve cover bolts and leave 2 of the center easy ones. Next warm the motor, then pull the cover.
If a valve is too loose, you will hear it clack. If you go too tight, you will hear the motor complain. So I guess you want to be somewhere in middle. :mrgreen: I used the stethoscope a lot too.
Maybe next time I could try backing out until the valve clacks and then going tighter just far enough to be quiet? Feel free to shoot this idea full of holes. :)
