It is currently Tue Nov 17, 2026 11:02 am
PostPosted: Wed Aug 21, 2013 11:09 am
does any one run all rubber lines on the transmission to their cooler ?
if not what do you run ?
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Aug 21, 2013 3:17 pm
running steel to hose to filter/hose to cooler
slant six's RULE!
PostPosted: Thu Aug 22, 2013 6:56 am
How long a length do you need? Earl's makes a really nice black nylon braided line that will hold up.
Regular rubber fuel line will break down and leak after awhile?
PostPosted: Thu Aug 22, 2013 8:31 am
There is purpose made transmission oil cooler rubber hose you should be able to get at any typical parts place.
I run steel tube from the trans to about the bellhousing, then braided teflon from there forward.
PostPosted: Thu Oct 03, 2013 5:33 pm
Car Model: 1965 Barracuda 'S' auto
Straight rubber heater hose degrades from the petroleum in the atf, makes them balloon up after a while and eventually leak. Go with the trans line from hayden or other trans outfits or purpose built hose.
PostPosted: Fri Oct 04, 2013 7:42 am
I agree with Pierre on using the correct hose made for tranny fluid.
I Also run steel lines to the rear of the tranny, cross under the tailshaft and up the passenger side of the engine to keep the lines away from the heat of the headers. Just a thought.
PostPosted: Fri Oct 04, 2013 8:05 am
Here is how the original pipes are drawn on Aspen/Volare, rubber hose only into the cooler.
Olaf
Aspenized
PostPosted: Fri Oct 04, 2013 2:54 pm
Diagram highlights a good point: always run an aux cooler after the rad cooler.
