It is currently Tue Dec 30, 2025 1:30 am
PostPosted: Tue Aug 20, 2013 9:21 am
When I was changing the oil and filter on my new (rebuilt) 225, I noticed the Oil Filter Attaching Stub didn't have a Tube like my old 1963 225 had. Is this a problem?
Racing Dart
 Post subject: No, but...
PostPosted: Tue Aug 20, 2013 9:35 am
No it's not a problem, but the tube would have been nice to prevent drainback of the oil if it was a concern. You can still change your stub for a tube (pull off your old oil pump or find one at a junkyard. The work around is Wix 1806 that has an anti-drain back mechanism in the filter itself so you can keep you stub and not need the tube.
FYI.
PostPosted: Thu Aug 22, 2013 11:11 am
The Summit Racing website says the Fram PH8A has the anti-drain back mechanism, also.
Racing Dart
PostPosted: Thu Aug 22, 2013 12:30 pm
Fortuitously-timed question - I just was wondering if I needed to swap out my taller stand tube from my '63 225 for the stub on the new Melling I installed. I'll be doing that now. Thanks for asking this question.
 Post subject: Lol...
PostPosted: Thu Aug 22, 2013 12:34 pm
Fram PH8A
:roll:
It also produces new clean oil and with every sale of 1,000,000 filters you get the deed to a bridge in Arizona that was for sale...
:lol:
PostPosted: Thu Aug 22, 2013 1:55 pm
Good one DI! :lol:
PostPosted: Thu Aug 22, 2013 1:57 pm
Use WIX Filters. Don't ever use FRAM.
WIX 51515 or WIX 51806 (if you don't have a stand pipe)
1964 Dart GT
PostPosted: Thu Aug 22, 2013 4:15 pm
To be nitpicky - wix 51806, 1806 is the napa number.
I'd rather use the 51806 instead of the original standpipe. The check valve in the standpipe is pretty restrictive looking.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
