It is currently Fri Nov 20, 2026 12:41 pm
PostPosted: Sun Aug 25, 2013 12:30 pm
Any good ideas what type of store might stock an 1/4-18 NPTF tap that I could locally try to source today (in LA)? I'm informed I need NPTF over NPT.
I'm drilling/tapping the temp sensor outlet in my '69 head for the larger 1/4-18 NPTF threads that '63 used. I have a good temp sensor and need to re-use it.
The usual suspects (Home Depot, Sears, Anawalt/True Value) have all failed me and I'd rather do this when the engine's on the stand, not in the car (which means I have to find it today - the engine is going back in today).
Anyone have ideas?
PostPosted: Sun Aug 25, 2013 1:49 pm
http://www.mcmaster.com/#pipe-taps/=o8093u
They aren't cheap, but if they haven't got it, you don't need it. :lol:
PostPosted: Sun Aug 25, 2013 7:09 pm
If you take the thermostat & housing out, you can stuff a rag in there and push it up towards the valves too then drill/tap. Been there, done that. Or maybe a small vacuum too aimed right under the hole.
PostPosted: Mon Aug 26, 2013 12:10 am
Car Model: 1964 Valiant V200
I am pretty sure you don't need NPTF, usually automotive is just NPT. NPTF is a special-dimensioned version of NPT anyway. NPTF is supposed to give better sealing; I bet that the temp sensor you have is threaded NPT anyway.
PostPosted: Mon Aug 26, 2013 1:32 am
I'd use NPT and use sealant on just the outer portion of the sensor (so there's still some metal to metal contact)
PostPosted: Mon Aug 26, 2013 7:08 am
Oh! are you saying you can find 1/4 npt but not 1/4 nptf? Yeah, you can cross the two... F just means no sealant necessary, think the formal name is dryseal. Use whichever tap you find, put sealant on it, call it a day.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
