It is currently Sun Sep 06, 2026 5:03 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
 Post subject: Carb Spacer
PostPosted: Tue Aug 06, 2013 8:18 am
Anyone find a benefit to running a carb spacer? Currently have a Clifford intake with a Carter AVS off a 273. I have a 1" & 2" HVH Super Sucker spacers available to try. I know they work great on V8's just not sure the SL6 will respond the same. I'm thinking it will give it better fuel atomization and maybe giving it a little more plenum volume might help on a combination strictly being used a bracket race car.
1972 Dodge Dart
Best ET & MPH 14.26 @ 92
 Post subject: Room under the hood.
PostPosted: Tue Aug 06, 2013 8:23 am
The taller versions work pretty good on the clifford intake, but the room under the hood of an A-body is limited due to the hood so you may note be able to get the 2" in there without a drop air cleaner.
I know of one Dodge Truck in Oregon that uses a 4" spacer and it increased the low end torque and overall driveability of the slant in the heavy vehicle.
 Post subject: Re: Room under the hood.
PostPosted: Tue Aug 06, 2013 9:01 am
Yeah there is limited space under the A-Body hood but i do have a drop base air cleaner on it right now and a couple others i can try. Torque is definitely what i'm after to improve.
1972 Dodge Dart
PostPosted: Fri Aug 09, 2013 10:32 am
On one of my early combinations I tried a 1" 4 hole spacer on a Clifford intake with a 390 Holley. It was worth a tenth in the 1/4 mile. :D
PostPosted: Fri Aug 09, 2013 7:21 pm
that is on the list of expierements I want to try on ruster drag car project. I have to modify the hood or cut some scoop onto there to do this project.
I have the same one Dennis describes.
Gary Bruner in TN. has a pretty tall 2 or 2.5 spacer on his Clifford manifold. he runs high 12s or low 11s in that car.
good luck.
PostPosted: Mon Aug 26, 2013 10:17 am
I tried the 1" spacer on ruster this weekend and did not see any clear advantage.
It was running mid 12.20s as it usually does in that weather.
I Might have to try a 2" or more spacer.
And thhat might require some hood modifications.
PostPosted: Mon Aug 26, 2013 10:37 am
Car Model: 64 Valiant
Were you using a 4 hole spacer or open. The HVH spacers mentioned above are a solid 68 HP gain and a mild SBC.....I know them pretty well there, the next time your in K'ville i'll see if I can arrange a private tour.
PostPosted: Mon Aug 26, 2013 11:24 am
It was a 4 hole.
The clifford Carb Adapter I have is a 4 hole so I think I would need to cut or modify the center section out of the clifford adapter to get the open one to work correctly or am I mistaken here?
PostPosted: Mon Aug 26, 2013 11:38 am
Here are the HVH quick fuel selections for a 4150 squarebore carb base as I have.
http://www.summitracing.com/search/bran ... h%20spacer
What do you sages suggest; as I was less then impressed with the No name aluminum 1" four hole spacer that I had tried :-(
Thanks,
PostPosted: Mon Aug 26, 2013 8:43 pm
I run a 2 inch spacer under my QF carb on my drag car.With a drop base, I can run a 2 inch K/N aircleaner.I also have a fiberglass hood on my 62 Valiant w/ no scoop.....and it fits. I KNOW my car is slower without it. :shock:
Wife's: 64 Valiant
PostPosted: Tue Aug 27, 2013 9:53 am
When the HVH spacers first came out about 9 years ago they were only available in the 2" thick size, and thus the 68 HP claims. A standard 1" thick design spacer might not always provide a noticeable increase in all situations. But I did design and manufacture a set of 1" spacers for a while that were a 2 hole design for the vintage carb 2 BBL market that when used as a 3 x 2 setup, showed a 15 HP gain.
PostPosted: Tue Aug 27, 2013 3:40 pm
So with a 1" spacer under a BBS I should get 7.5 HP.........
:wink:
PostPosted: Tue Aug 27, 2013 8:59 pm
Well maybe not with your garden variety spacer, but with mine I would say that is reasonable to expect. 8)
PostPosted: Wed Aug 28, 2013 4:00 pm
Forgot to mention, Mine is a Moroso non metallic open design.
Wife's: 64 Valiant
PostPosted: Wed Aug 28, 2013 5:24 pm
I suggest that $127 is too much for a carb spacer!! Wow, I am in the wrong business.
Rick
Yeah, yeah,I know. Speed cost money, how fast do you want to go!
