It is currently Sat Jun 13, 2026 6:19 am
 Post subject: no reverse
PostPosted: Tue Sep 03, 2013 9:42 am
looks like the rat dart w/old school trans act manual valve body has no reverse. it goes into gear and kinda moves but not over a small 2 inch concrete yard rise.
plenty of fluid synthetic that looks clean.
putting on exhaust pipes/glass packs so I can street drive and see how gears work...
slant six's RULE!
http://www.usajon.com
 Post subject: .
PostPosted: Wed Sep 04, 2013 9:02 am
Did the Trans work before installing the valve body,was the low-reverse band adjusted to the correct specs for the model year trans
PostPosted: Wed Sep 04, 2013 9:39 am
Don't you need to activate the trans brake to use reverse?
PostPosted: Wed Sep 04, 2013 10:01 am
you know that's very possible as it was orig made 4race app ...old school. I did get a hand written note from previous owner stating something about putting it into reverse b4 activating the trans brake..will check it out.
slant six's RULE!
PostPosted: Fri Sep 06, 2013 7:19 am
Online
Somtimes to reverse with the transbrake you Put it into "N" and then Push the button = "R"
