It is currently Sun Oct 11, 2026 4:04 am
PostPosted: Fri Sep 06, 2013 8:18 pm
The bolt pattern from the bottom of the carb doesn't match the smaller bolt pattern on the offy, the holley has a much larger spread .. Anyone know of some sort or " pyramid " adapter that will work?
Aloha
1966 valiant 200 wagon
PostPosted: Fri Sep 06, 2013 8:51 pm
6 Pack Dart
Look at this and you will see the part you need to get the carb to fit, Clifford also had this.
http://www.summitracing.com/parts/ofy-5 ... uiredparts
Richard
 Post subject: Offy 4bbl/ holley 390
PostPosted: Fri Sep 06, 2013 10:39 pm
Thanks for the link, that's the linkage I need? I just talked to the guy I got the intake from and he said he used to have an adapter plate or something.
Any help is appreciated ! Spent this last Labor Day weekend pulling motors and transfer to get what I wanted to replace the /6 in my wagon. Scored some headers too.. :twisted:
Aloha
PostPosted: Fri Sep 06, 2013 10:59 pm
Site Admin
The adaptor plate is available from Offy, or Clifford. Cheaper from Clifford last I checked.
http://www.cliffordperformance.net/Merc ... gory_Code=
CJ
PostPosted: Sat Sep 07, 2013 2:31 am
Thank you sooooo much, I will post pics later
Aloha
PostPosted: Sat Sep 07, 2013 8:35 am
The Clifford adapter is also nicer than the Offy piece.
PostPosted: Sun Sep 08, 2013 12:08 am
Is Clifford sending out regularly? If you order, would you get your stuff soon, Clifford had an iffy past....Jerry
PostPosted: Mon Sep 09, 2013 8:42 am
I'm not sure , ended up using a hand-me- down holley adapter, polished right up...
Aloha
Users browsing this forum: Amazon [Bot] and 22 guests
