It is currently Mon Jun 15, 2026 10:28 pm
PostPosted: Mon Sep 09, 2013 12:48 pm
Anyone have any tips on fabbing a lil linkage for this?
Aloha
1966 valiant 200 wagon
PostPosted: Mon Sep 09, 2013 2:18 pm
get a cable system-from one of the after market companies-- you will need to switch the gas pedal to a cable style also-- unless you can find the 65-66 cable style($$)
PostPosted: Tue Sep 10, 2013 4:07 pm
Thanks for the response, I am going to attempt to make my own "custom" rod linkage to cable set up for it using a auto parts store cable kit and a spring and pulley . I think I got it figured out, will post pics soon
Aloha
PostPosted: Tue Sep 10, 2013 4:46 pm
Offenhauser made a linkage retrofit kit to use a 4 barrel on their manifold using a modified rode for the early A Body. I'd have to dig it out of my parts to see exactly what needed to be done.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Sep 10, 2013 5:47 pm
This is what I used for a 904 transmission, and cable :
http://www.bpeusa.com/BPEtkdc.asp
My 67 came with cable operated accelerator from factory, but a pedal from 67 on up including K Cars is easily mounted and connected to the above BPE accelerator cable bracket that is designed for Mopar factory cables. It is an easy install requiring no fabrication; you would need to drill a few holes in floor to mount a pedal, and cable.
PostPosted: Tue Sep 10, 2013 9:12 pm
wjajr is right. I have personally used that kit before, and it is very good.
Brian
Flyin' Brian
"Sixy Beast"
