It is currently Tue Oct 13, 2026 2:44 pm
PostPosted: Tue Sep 10, 2013 10:23 pm
Good fuel pump, brand new 390 carb, no gas is getting to the fuel filter , Is three gallons enough to get pumping? Help!
Aloha
1966 valiant 200 wagon
PostPosted: Tue Sep 10, 2013 11:00 pm
I just went through this after replacing the gas tank on my brother's 74 Duster. Three gallons is plenty to get fuel to the carb. The fuel pump will take a long time to get the fuel to the carb if all you do is crank it with the starter. A much faster way is to fill the float bowl with something that the engine will run on and then the fuel pump will be able to pull the gas through the fuel lines and start pumping. Spray some carb cleaner down the vent tube of the float bowl (about a 20 second spray) to fill the float bowl. Now start the car and I bet the fuel pump will draw the gas from the tank.
PostPosted: Wed Sep 11, 2013 5:46 am
I wouldn’t load the bowl with starter fluid, it’s too volatile.
Here is how I fill an empty bowl by partial filling through its vent. Just don’t over fill, as raw gas will drain down into intake manifold causing flooding. The bottle is from Walmart for under a buck.
PostPosted: Thu Sep 12, 2013 9:42 pm
Nice... What linkage or cable set up are you running? Did the dart come with cable? Any ideas on a conversion?
Thanks for all and any help
Aloha
PostPosted: Fri Sep 13, 2013 6:39 am
For some unknown reason I thought that I had posted info on your 390 conversion thread on my set-up. I'll do that now.
Users browsing this forum: Amazon [Bot] and 14 guests
