It is currently Fri May 15, 2026 2:02 am
PostPosted: Mon Sep 16, 2013 12:46 pm
Hello,
I was Just curious about lower control bushing removal.
I was able to remove the stud from the center with the press.
After removing the stud is there a correct way to get the rest of the bushing / Shell out?
I just burned the rubber out with a torch and then took a die grinder and ground a line down on the inside of the outer sleeve until I had enough play to knock it out with a chisel.
is there another way to do it?
Just curious.
PS.. pressing it back together was a breeze!
PostPosted: Mon Sep 16, 2013 1:33 pm
You've already come to one of the best methods going by grinding out part of the bushing shell. Some weld a washer to the shell so it can be pressed out. Of course this requires access to and use of a welder.
PostPosted: Mon Sep 16, 2013 1:36 pm
thanks josh!
I do have access to those..
PostPosted: Tue Sep 17, 2013 7:33 pm
If you are going with a poly bushing you need to leave the inner sleve attached to shaft. If not remove it the same way by cutting a few slots along the length with a cut off wheel/die grinder.
PostPosted: Wed Sep 18, 2013 9:36 am
Thanks Romeo.
This was with a standard bushing install.
So No saving metal shells.
PostPosted: Fri Sep 27, 2013 3:38 am
I welded a washer in when we did ours. We used the nylon bushings from Firmfeel, which apparently don't require saving the outer sleeve.
Escape Velocity Racing
 Post subject: LCA bushing removal
PostPosted: Sun Dec 08, 2013 6:33 pm
Mopar Muscle has this tutorial:
http://www.moparmusclemagazine.com/tech ... _bushings/
bg
PostPosted: Mon Dec 09, 2013 7:27 am
Nice article and photos, best I have seen. This write up has been added to my Favorites Suspension folder along with a video showing how to take the slop out of a lower control arm; thanks.
