It is currently Mon May 04, 2026 7:15 pm
PostPosted: Wed Sep 18, 2013 3:45 pm
how many of you are making good power without water or meth injection?
PostPosted: Wed Sep 18, 2013 5:18 pm
I am OK to at least 280 crank HP on 6 psi boost w/o intercooler or water/meth inj.
PostPosted: Wed Sep 18, 2013 9:24 pm
just read your build thread. did you wind up using a regular intercooler?
PostPosted: Wed Sep 18, 2013 9:51 pm
My car ran fine without the meth and water at 10psi. I'm still currently at 10psi with meth injection because I want to crank the boost up soon. I haven't done so yet since I've moved farther for college and would like to keep everything not broke for a bit longer :) I'm intercooled also
Kev
PostPosted: Wed Sep 18, 2013 9:57 pm
how much higher do you plan on going that you would need the meth?
PostPosted: Wed Sep 18, 2013 10:55 pm
I would like 20psi would be a nasty daily driver! The meth injection just is a little extra safety net for the motor or my tune.
Kev
PostPosted: Thu Sep 19, 2013 1:30 pm
I have no intercooler as yet. The Meth/H2O should cover that, at least at these boost levels.
