It is currently Fri Jun 05, 2026 5:01 pm
 Post subject: bad alternator
PostPosted: Mon Sep 16, 2013 6:16 am
alternator is bad back up only charges @ hi rpm.
wondering if there's a better up grade that bolts in to our 1968 dart rat .
any thoughts..
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Sep 17, 2013 2:38 pm
Use the Nippendenso alternator from a (either, not sure which) 88 or 89 dakota with a V belt pulley. Cut about a 1/4 inch off the front of the alt mounting bracket. Done.
PostPosted: Tue Sep 17, 2013 5:00 pm
is this it Charlie ?
http://www.ebay.com/itm/USA-INDUSTRIES- ... 53&vxp=mtr
slant six's RULE!
PostPosted: Tue Sep 17, 2013 6:31 pm
No. It looks like this. They came with either a 2 shive v-belt pully, which is what you need, or a multi groove pully for a serp belt.
http://www.ebay.com/itm/DENSO-210-0138- ... 9d&vxp=mtr
There are a lot of them in salvage yards
PostPosted: Tue Sep 17, 2013 6:36 pm
True! they only charged me $20 for mine off of a 92.
PostPosted: Wed Sep 18, 2013 9:59 am
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Since the ND alternator is higher output, I'd assume the factory wiring needs to be upgraded??
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Wed Sep 18, 2013 12:20 pm
Correct
Yes, I did the SL6 Dan wiring mod with two 10 gauge wires and circuit breakers.
PostPosted: Thu Sep 19, 2013 12:35 pm
why would one go with a higher output alternator in general for a non option car
had mine tested @ advanced auto
it was OK
bought a regulator on the 9th and it arrived on the 12th and it charges great..
cheap/new
http://www.ebay.com/itm/251307726713?ss ... 1439.l2649
slant six's RULE!
PostPosted: Thu Sep 19, 2013 1:07 pm
Improved charging at idle, smaller form factor.
PostPosted: Thu Sep 19, 2013 2:31 pm
Smaller form factor! HA!
Just be glad you ain't got one of the original Mopar 100 amp units! Like my NYB, bulletproof, but man are they big.
I think I do remember seeing them on some slants, maybe fleet use?
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Thu Sep 19, 2013 2:35 pm
I once pulled a 100 amp alternator and the associated brackets and wiring harness off of a 83 Dodge van powered by a slant six. It was in the junkyard and had the 100 amp alternator to provide power for the rear window defrost grid. If memory serves, that grid alone draw 35 amps. I imagine that any fleet vehicles or vehicle that had the rear defog grid would have needed at the very least the 65 amp alternator, if not all the way up to the 100 amp. I recall having seen late 70s slant powered LeBarons with the 100 amp alternator as well.
PostPosted: Thu Sep 19, 2013 2:41 pm
Canadian spec Mopars got the defrost grid as standard from about 78, like my NYB. So that makes sense!
Mattelderca
PostPosted: Thu Sep 19, 2013 2:57 pm
http://www.ebay.com/itm/GM-Single-1-one ... a3&vxp=mtr
slant six's RULE!
PostPosted: Thu Sep 19, 2013 3:28 pm
(1) cost
(2) chromed metal does not cool as well as natural finish metal
(3) I prefer externally regulated alternators for purposes of repair
