It is currently Sat Aug 15, 2026 3:26 pm
 Post subject: supcharger cam
PostPosted: Thu Aug 08, 2013 5:49 pm
I have read a tons of posts and with the answer to this question I will go back and read more .. Is a cam for supercharger about 5 to 6 psi same as a turbo cam ? My car will be 8:00 to 1 comp. And I have a b&m forced induction unit aiming for 5-6 psi boost and max rpm of 5500-5750 RPM'S eng bldr valves and ported head . Please ideas about cams and buy a new blank or regrind mine ..? Thank you all. Smitty [/b][/u]
1963 Plymouth Valiant Wagon
PostPosted: Tue Sep 24, 2013 1:48 pm
I used the engblder valve with 10psi and a .540lift 255@.050 108center, ran 11.6 with 4.56 rear gears 30" tall tires. in you case for the street, a .490 lift and 230@.050 and a higher stall converter 2500rpms should be nice.
