It is currently Tue Feb 18, 2025 5:03 pm
PostPosted: Thu Sep 26, 2013 8:36 am
Wanna get my head shaved .100, can I get it done with the valves in the head?
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Thu Sep 26, 2013 9:34 am
6 Pack Dart
That is not advisable pull valves keeping in order for reinstallation. Way too easy to clean head after cutting.
Richard
PostPosted: Thu Sep 26, 2013 10:03 am
I had a head off the engine. Called the machine shop to see if I get it to them on Monday afternoon, if I could get it back by Fri, cut .100. Shop told me if I got it to them in an hour, I could have it back the same day. Took the the complete assembled head, except for removeing the bottom row of manifold studs. When I got the head home, I totally disassembled it for a good cleaning.
PostPosted: Thu Sep 26, 2013 10:26 am
I had mine done fully assembled. When it was done I took it home and washed it with solvent and blew it out really well. No issues. :D
PostPosted: Tue Oct 01, 2013 4:21 pm
What did a .100 haircut cost?
PostPosted: Tue Oct 01, 2013 8:04 pm
Mine cost $60.00
PostPosted: Tue Oct 01, 2013 8:28 pm
A $60 haircut? Must be one fancy barber.
PostPosted: Wed Oct 02, 2013 4:57 am
He in not a barber, he is a "stylist".
PostPosted: Wed Oct 02, 2013 10:04 am
I've done this as well.
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Oct 02, 2013 12:34 pm
I find taking things apart to inspect their condition and wear patterns is invaluable in learning about my engine. A valve spring compressor isn't an expensive tool, so I'd suggest disassembling it before you take it in just for the sake of learning. Then you can clean off any buildup on the valves and seats as well.
PostPosted: Wed Oct 02, 2013 1:54 pm
Good time to break this out, diy valve seat scraper. Carbide cutting tip brazed into an old valve, insert, chuck in cordless drill and use low speed and cutting oil.
Users browsing this forum: Ahrefs [Bot], eric22t and 15 guests
