It is currently Thu Jun 04, 2026 5:15 am
PostPosted: Thu Sep 26, 2013 6:45 am
I keep seeing SL6 A727. What I have in my 1980 Dodge is a Loadflite A727 w/lockup. I am pondering dropping a small block LA V8 into this truck. Will the trans bolt up and work? TIA
PostPosted: Thu Sep 26, 2013 7:26 am
No. The bellhousing is completely different between the slant six and v-8 versions. You will need to get a v-8 transmission if you want to put a v-8 in your vehicle.
PostPosted: Thu Sep 26, 2013 8:28 am
thanks, I'll be keeping the SL6 then.
PostPosted: Thu Sep 26, 2013 8:55 am
Wise choice. If you are looking to free up some horsepower, consider switching to a 904. If you get one form the 80s it will have the wide gear ratio gearset that help heavy vehicles like pickups get moving from a stop.
PostPosted: Thu Sep 26, 2013 10:17 am
Reed,
I don't want to swap trannys tho. The one I have is like new.
I still need to solve this flat spot off idle. How would you go about troubleshooting something like this? Once I get past the initial stumble everything seems right.
After I get that sorted out I'm going to rig up cold air ducting and install an electric fan. Should be worth a little more power.
PostPosted: Thu Sep 26, 2013 12:47 pm
Sounds like your pump shot (accelerator pump) is weak.....
with the engine off, take a peak down the throat while giving it a quick pump.
Does it look like someone turned on a fire hose? or is it weak.....
PostPosted: Thu Sep 26, 2013 1:02 pm
Yup, what Ted said. Check the pump shot on your carb and also verify that the vacuum advance on the distributor is properly hooked up and is functioning correctly.
PostPosted: Fri Sep 27, 2013 8:27 am
Ok thanks gents. Hopefully I'll get some time this weekend to look at her.
