It is currently Fri Jun 19, 2026 7:13 am
 Post subject: manifold swap
PostPosted: Sat Sep 28, 2013 4:42 am
Hi l have a 87g.
b250 ram van+exghaust manifold crack
ed.l found a loose engine on the ground so i dont know what it came out of it does not have the big metal disc on heat riser shaft+has open pocket choke pulloff its also painted orange.anyway the 3 intermanifold gasket bolts dont want to unscrew.if i just install these "new" manifolds as a unit; what are the chances of the intermanifold gasket leaking.thx
jackmcginn
