It is currently Tue Oct 13, 2026 12:06 am
 Post subject: Help please
PostPosted: Sun Sep 29, 2013 10:11 am
I have an '80 Vloare wagon, and over the weekend I adjusted the valves on the slant 6 in it. When I took the air cleaner housing off I found a disaster, the wiring has been butchered, the vacuum hoses unplugged and left off, and the top of the carb is loose! When I went to tighten the carb screws I discovered the holes are stripped, so I will be replacing it when I can find one (I may have one in my assortment of "stuff") but I need diagrams for the vac and wiring. If there is someone who can point me to those online that would be a big help. Thank you.
Dave
1972 d-100 parts truck
PostPosted: Sun Sep 29, 2013 10:33 am
Six dollars on eBay. Can't beat that with a stick!
PostPosted: Sun Sep 29, 2013 2:41 pm
Helicoil will repair striped female thread. Check tool aisle at auto parts store, or Sears for common size kits.
PostPosted: Mon Sep 30, 2013 2:12 pm
If it were me, I would spring for the two volume set:
http://www.ebay.com/itm/1980-DODGE-MIRA ... 3150235%26
at $24.99 to cover all the systems of the car, at least if keeping and maintaining it was in the plan.
BC
PostPosted: Mon Sep 30, 2013 2:31 pm
I second the suggestion for getting both manuals. I didn't know that the car manuals had begun to be broken out into separate manuals as early as 1980. At least as late as 1986 truck and vans still had single volume shop manuals.
Users browsing this forum: No registered users and 14 guests
