It is currently Sat Nov 14, 2026 9:29 am
PostPosted: Sat Apr 06, 2013 4:30 pm
anybody use the 36 tooth missing tooth trigger wheel with hall effect sensor?
they have one on the DIY site along with the mega squirt MSIIIX. yea or nay?
http://www.diyautotune.com/catalog/14-3 ... p-180.html
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sat Apr 06, 2013 6:04 pm
I used a similar wheel that I got from an Ebay seller, and used the Ford sensor that came from the car the EDIS module came from.
But I don't use the MS in my truck, I use the Megajolt Jr.
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Sun Apr 07, 2013 5:31 pm
I use DIY wheel & pickup with no problems, its pretty straight forward as long as wheel is mounted with less than .010 runout
PostPosted: Sun Apr 07, 2013 5:33 pm
i was gonna make a milled spacer to mount to my romac so it should be dead on
PostPosted: Sun Apr 07, 2013 5:52 pm
You should have no problems useing there pieces
PostPosted: Sun Apr 07, 2013 5:57 pm
cool cool!
PostPosted: Mon Sep 30, 2013 8:44 am
Car Model: 1965 Barracuda 'S' auto
Ed, check out my new wheel. Image
PostPosted: Mon Sep 30, 2013 10:02 am
oooo sexy! did you just machine down a stock balancer? also have you though about the repercussions of doing that? and I mean as far as having the balancer being less efficient?
PostPosted: Mon Sep 30, 2013 12:36 pm
That is to be determined. Im not even sure if the balancer is tuned to the motor, mass wise, and then at what rpm? Well, its a start, Well see. This is a stock damper but there are many configurations of these in my looking for the right candidate. I think this was a very early example as the balance (?) scallop was taken out of the thinner front rim and the back rim was uniform, thicker at about .200 wide. My 67 had the scallop out the front and the back was too thin, all the mass was in the front rim. So just an FYI. Most trigger wheels on the net are 5mm thick or about .200, very good for the stock Ford VR sensor that has a sensor width of. 250, the size of the crowns of my teeth.
PostPosted: Mon Sep 30, 2013 6:03 pm
Maybe a 60-62 as i saw a nos 63 that was like my later one, beveled rear with thick scalloped front. If this doesnt pan out, ill burn off the toothed ring and mount it to a A/C rear mount pulley so as to make it hub rigid and still have a close to the block wheel.
PostPosted: Mon Sep 30, 2013 6:21 pm
That looks great!!!
Will
