It is currently Thu Jul 16, 2026 2:40 am
PostPosted: Thu Oct 10, 2013 8:48 am
Flatout Gaskets & Fabrications
668 Tower Rd.
Mundelein, IL. 60060
(847) 837-9200 P
(847) 837-9628 F
www.flatoutgroup.com
Here is a new source for rubber coated copper head gasket for the slant. It's not in the catalog yet but here's the base part number 9874 you will need to no what bore and thickness. Also the recommend O ring the block or head.
Also you will have to call and order direct from the company none of the distributors have it in there catalog
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Thu Oct 10, 2013 6:36 pm
Did they say how thick of gaskets they have available?
PostPosted: Thu Oct 10, 2013 7:30 pm
From the email I received any bore size any thickness
PostPosted: Fri Oct 11, 2013 10:18 am
Car Model: 64 Valiant
I'm getting some made now to go along with the intake/exhaust gaskets I already have available. Mine will be .040" thick, big bore of course.
PostPosted: Fri Oct 11, 2013 1:08 pm
So what does big bore equal? Also does the intake exhaust gasket have the big port openings? How thick are they?
Aaron
PostPosted: Mon Oct 14, 2013 3:40 pm
There made to accomodate a 3.500" bore. The intake/exhaust gaskets are made with larger ports to accomodate a ported head and are .060" thick.
