It is currently Sat Jun 20, 2026 1:05 am
 Post subject: Holley 2280 carb spacer
PostPosted: Mon Oct 14, 2013 8:31 pm
is there a such thing ? I do need the "gasket" that goes in between the carb and the manifold
1972 Dodge Dart Swinger with a 225 Slant Six
PostPosted: Tue Oct 15, 2013 4:43 am
I doubt you need a carb spacer unless there is a interference issue with the throttle linkage or some other part.
As I remember the Holley 2280 is a replacement carb for the Carter BBD on some 318s I would guess that a spacer and gasket(s) from that application would work.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Oct 15, 2013 6:10 am
I have never seen one, but that doesn't mean you can't make one. The issue will be hood clearance if you go too tall.
Yes, you need the thick one so the linkage will clear the intake manifold.
http://www.slantsix.org/articles/supersix/article.htm
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
