It is currently Wed Aug 05, 2026 9:26 am
 Post subject: Distributor Recurving
PostPosted: Thu Oct 17, 2013 12:17 pm
Who do you recommend I send my 225 Slant Six distributor to for recurving?
I need the Automatic Advance set to 24 degrees at 3200 RPM.
I now have a 260 degree cam in my 225 Slant Six engine.
Racing Dart
 Post subject: Diy
PostPosted: Thu Oct 17, 2013 6:57 pm
I no longer am able to perform this service so you are "do it yourself"...the only way to get that many degrees is to limit a 13R governor with a little wire or welding...personally 18-20 is best-9 or 10L governor- and 24 will not allow a fair amount of initial (i.e. you will set that distributor at 6BTDC to get 30 mechanical).
You should be able to order big six fan's spring kit and install it with the curve for the rpm and advance closest to desired. (Tools needed are a couple of screwdrivers and needle nose pliers to remove the governor spring clip and away you go...)
PostPosted: Fri Oct 18, 2013 9:26 am
Hi,
Where can I order the "big six fan's spring kit" from?
Racing Dart
PostPosted: Fri Oct 18, 2013 9:54 am
Top of the page in Parts for sale. Drop him a PM.
Link here. http://slantsix.org/forum/viewtopic.php?t=52750
Users browsing this forum: Google [Bot] and 16 guests
