It is currently Tue Jun 02, 2026 9:56 am
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 145 46 47 48 49128 Next
PostPosted: Sun Oct 27, 2013 2:32 am
Wonder if the piston seized in the bore? That would explain the rod being pulled apart.
I love a good mystery. :D
PostPosted: Sun Oct 27, 2013 6:20 am
I've seen more block failures and valve failures in the speed game.
did you pull the valve cover yet ?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Oct 27, 2013 11:25 am
I looked back at my build and found my clearances on the rods were at .0025, which seems a little loose for a brand new build. Now that things have gone south, it makes sense that perhaps the rods bolts oblonged the rods causing my reading to be high at the middle of the cap and probably tight on the sides.
I have not touched the car other than to drop a magnet into the hole, but I will pull the valve cover in the morning and just take a quick look and make sure that all the valves are still in the head.
Rick
PostPosted: Sun Oct 27, 2013 12:55 pm
In thinking about it I think it is most likely that a valve or something kept the piston from going all the way to the top and thus the elongated small end and eventual break. I think Jon is on the right track.
PostPosted: Sun Oct 27, 2013 8:32 pm
Car Model: 64 Valiant
Rick
Not likely that your bearing clearance was too much Rick. I know a lot of guys also look at their Mopar service manual as the holy grail of engine specs, but it is really meaningless when it comes to prepping an engine for any kind of performance usage. It was written specifically as a stock engine guide, and shouldn't even be considered as a tool for prepping any sort of performance apps. Building and prepping an engine for performance is in a completely different league and has its own set of rules and specs that are rarely the same for a stock engine rebuild. Your rod bearing clearance is really right on the money. What was your rods side clearance also? I also have found in my years in the machine shop that the worst rods were the so called ones that were already "reconditioned" ones you buy at the parts store, the same goes for crank kits and rebuilt heads. So if you hadn't changed the rod bolts in these rods, chances are you wouldn't have had them checked to confirm they were dead on on their housing bores either, and could likely be facing the same problem.
Your rod failure problem was more than likely caused by the rods being out of round and caused this. Just look at the bearings in your surviving rods and you'll probably see a recurring pattern of telltale signs showing it. This was just an oversight and shouldn't make you steer clear of attempting to use their products. To answer your question in the other post, you should always consider upgrading to better engine fasteners, especially rod bolts, because you never know the history of the rods or blocks you buy from junkyards or swap meets, its just good cheap insurance. And people are going to always tell you the engine came out of their grandpa's truck our their 90 year old aunts car when they are trying to sell something.
 Post subject: nothing beats the truth
PostPosted: Sun Oct 27, 2013 8:51 pm
I rode this Harley chopper 3 years straight as I it was my only transpo. I retarted the timing so it would start in the winter.(kick start only) Being retarded it heated the exhast valve so much it shattered, bounced around the head /and went out the exhaust at 85 mph on route 40 headed to my bros house in Monrovia( 4wheel Harry) , Maryland.piston had dents, spark plug was shot, but sanded down the combustion chamber/piston and new valve and ran OK...
http://www.youtube.com/watch?v=-vTe0yrLEoU
slant six's RULE!
PostPosted: Sun Oct 27, 2013 11:16 pm
Your lucky, it usually at the least bends or twists the rod by some amount and/or closes up the top ring land on the piston.
PostPosted: Mon Oct 28, 2013 6:41 am
One more piece of the puzzle.
Pulled the valve cover and it did not drop a valve. Everything is in tack up top. However when I got a small flashlight out and began to look a little closer behind the headers you can see in through the front frost plug hole. There is a large hole through the cylinder wall.
Perhaps the cylinder wall gave way and started all of this. Or perhaps the rod just poked a hole through it. Time will tell. It is .100 oversize. Time will tell
Rick
PostPosted: Sat Nov 02, 2013 10:22 am
the valve never dropped. just the face part in photo shattered/rattled around did some minor damage then flew out the open drag pipes..
slant six's RULE!
PostPosted: Sat Nov 02, 2013 10:25 am
rick I did not read your build, but those chevy 2.2 pistons look short/stubby compared to the regular slant six coke can pistons..
correct me if wrong on the pistons..
has anyone else had an issue with stubby pistons in a slant ?
they would seem to rock more in cylinder then a stock length piston 2me.
slant six's RULE!
PostPosted: Sat Nov 02, 2013 1:15 pm
Nope, not that I know of. Lou is running the same exact piston/rod combo in project V.
Rick
PostPosted: Thu Nov 07, 2013 4:04 pm
I was able to get the intake and headers out of the way on my engine and get a better look at things. The crank did not spin a rod bearing. If you look at the pictures the journal is perfectly smooth on the one side and beat up from the pieces letting go on the other. But it did not spin. I also fished out a ARP bolt that was snapped in the middle and it still has the nut on the stud.
Nice smooth journal
Other side of the same journal
I also fished out some other pieces of the cylinder wall and the thinnest piece I have found measured over .177 thick.
Pulled # 2 spark plug and it looks perfectly fine.
More to follow.
PostPosted: Thu Nov 07, 2013 7:23 pm
Rick, does it look like the bolt broke underneath the head where you had to grind it to fit the rods?
PostPosted: Fri Nov 08, 2013 6:41 am
No it broke in the middle, about where the rod would part. I'll get a picture.
Rick
PostPosted: Fri Nov 08, 2013 12:40 pm
No, the piston pushed down easily through the spark plug hole. So it is not seized.
Here is the picture of the rod bolt. It looks like a smoother break on both sides and jagged it the middle. Does that mean somthing? I don't know. I may get the head lifted off tomorrow, and then I can see the bore and piston (whats left of it)
Rick
