It is currently Wed May 27, 2026 11:57 pm
 Post subject: Aftermarket 198 rods
PostPosted: Tue Jul 09, 2013 9:51 am
I first found these K1 rods on ebay for just under $500 for a set of 6, $525 on this site.
http://www.campbellenterprises.com/slan ... g-rods.php
They also have Molnar for only $450 a set.
http://www.campbellenterprises.com/moln ... antsixrods
I've heard those 7.005" 198 rods can be hard to find from time to time. Nice to see there's an AM solution, albeit pricey. K1 is even good enough to make one set for forged cranks and one for cast (which is what I'm working with).
Part #s
K1 - Forged - dh7005behb6-a
K1 - Cast - dh7005behb-N6-a
Molnar - DH7005UHB6
Anyone with experiences or criticisms, feel free to comment.
PostPosted: Tue Jul 09, 2013 11:58 am
Car Model: 1964 Valiant V200
Many people on here have used the K1 rods, they have been out for 3 years now. I have a set going in my motor that is with the machinist. I have not gotten to the stage of checking the big & small end bores and eccentricity, but I imagine they are pretty good. The machining takes place in the US even though the forgings are chinese. I think Molnar is similar.
 Post subject: Oil holes..
PostPosted: Tue Jul 09, 2013 12:32 pm
Somebody should sound off on the latest set of rods since I think the K1 had a small issue with oil hole locations in them, but everything else was good quality.
PostPosted: Tue Jul 09, 2013 12:33 pm
Mine are about 2 months old, direct from K1. I'll check and let you know.
PostPosted: Tue Jul 09, 2013 3:33 pm
Well that's irony... a little over 3 years ago, I retired my slant car and figured I'd get around to a rebuild "someday" because I couldn't find anyone with rods out of a 198 for sale at the time... it's taken me this long to get back to it.
 Post subject: Lol...
PostPosted: Tue Jul 09, 2013 3:58 pm
LOL, that's life...
Too bad you were more local, I'd save you the parts,time and block machining...got one in the parts for sale section...
 Post subject: Re: Oil holes..
PostPosted: Tue Aug 13, 2013 4:58 pm
My recent production rods checked out perfectly. Big end bores were within .0005, or as close as I can measure them. Small end bores were within .0001. Small end pin clearance is a little on the tight side for a high rpm drag motor, .004, but fine for a street motor. Notches are in the right place and the right width.
PostPosted: Tue Aug 13, 2013 5:26 pm
We bought a set of K-1's about three years ago and have had zero problems with them, running 10-pounds of boost and 5,500 rpm repeatedly with them.
That has been our experience in a turbo 225 motor with a 904, in a 2,700-pound car.
Bill, in Conway, Arkansas
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Sat Nov 16, 2013 5:32 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
What piston is everybody running with the aftermarket rods?
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Sun Nov 17, 2013 2:41 am
The Wiseco piston is the offering that most people use. It's a great racing setup.
This piston should run at zero deck. There are variations in decks, but it will be close. Pay close attention to combustion chamber size, as a modified head can push compression past pump fuels.
What kind of fuel do you want to use? There are metric options, but you may need either a custom piston or modified small end to work with a different pin size.
 Post subject: Wiseco pistons....
PostPosted: Sun Nov 17, 2013 10:20 am
Measured with a some colored olive oil and a burette, (and a 1/4"-thick see-thru plastic plate,) our combustion chambers came out tp exactly 9:1, with a non-milled head and a non-milled deck. That was with a .020"-thick gasket, un-modified chambers, and six, off-the-shelf, Wiseco 3.465" pistons and K-1 rods.
No problems. so far (with that setup.) LOTS of problems, otherwise... LOL!
Bill
PS, we set the end-gap on the rings at .024" top and .022" 2nd. Maybe a little tight...
PostPosted: Sun Nov 17, 2013 6:20 pm
I know it sounds strange but these rods wouldn't work with a press fit type piston would it?
 Post subject: so green, here...
PostPosted: Sun Nov 17, 2013 9:48 pm
The rod's wrist-pin diameter is likely too big for a press-fit pin, but if that's what you want they could deliver them to you with a smaller diameter. You just need to call them and tell them what you want; they are very accommodating.
Give them a shout; all they can say is "no....".
The Wiseco/K-1 setup went together very smoothly... :) And, we were/are novices of the first magnitude...
PostPosted: Tue Nov 19, 2013 1:20 pm
You used the wiseco off-the-shelf pistons and got 9.0:1???
I can't see how that's possible - my head is only milled .020, and relieved to be near stock cc (55/56cc) and I am at almost 10.5:1 with some pop-up.
