It is currently Sun May 24, 2026 1:44 pm
 Post subject: oil cap seal?
PostPosted: Thu Nov 21, 2013 1:56 pm
Is there a replacement seal for the valve cover oil cap? All of the 4 I have are brittle and falling apart. Maybe an aftermarket one is available? [/quote]
PostPosted: Thu Nov 21, 2013 5:57 pm
Something like this? http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
PostPosted: Thu Nov 21, 2013 6:26 pm
Nope those are all the breather cap. I need the oil fill cap seal. My valve cover has 3 holes one for cap one for pcv and one for breather.
PostPosted: Thu Nov 21, 2013 6:30 pm
PostPosted: Thu Nov 21, 2013 7:24 pm
http://www.ebay.com/itm/Mopar-Engine-Va ... 0802529564
or this
http://www.jegs.com/i/Mopar+Performance ... 7Aod5G0AfQ
1964 Dart GT
PostPosted: Fri Nov 22, 2013 7:24 am
Why don't you make one from some old inter tubes or sheet rubber..
Probably a nice set of tin snips, a pair of scissors and an xacto knife / Razor blade is all you need to make one.
PostPosted: Fri Nov 22, 2013 8:09 am
STANT Part # 10066 $1.08 at Rockauto.com
 Post subject: Oil cap rubber seal
PostPosted: Fri Nov 22, 2013 8:15 am
Agreed! pretty easy to make. I keep some sheet rubber handy for such needs.
Besides making seals for the oil cap when they wear out, I also make them for radiator caps when they wear out and no longer recycle radiator fluid from the over flow tank.
