It is currently Sun Mar 16, 2025 10:54 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Fri Nov 22, 2013 7:00 pm
I think if I map out the inside wires, and the outside ones, I can boil this down to just a few wires that do not have a positive ID. It would just take a little time. Maybe it would come down to just one, if I am lucky.
Sam
PostPosted: Wed Nov 27, 2013 6:39 pm
Rating a cooler by vehicle weight always seemed odd to me. I'd imagine trans fluid temp varies with much more then just weight of the car it's in.
And the transmission has to work harder if you're loaded or towing. Wouldn't the 24000 GVW rating mean that it is capable of keeping the temps down when you're hauling 24000 lbs around? I know a Dart is a solid old car, but it surely doesn't need that level of overkill. Unless you were planning to drive a lot of uphill in desert conditions, like Bakersfield to Vegas for example. Then I'd recommend doubling everything-- radiator, tranny cooler, AC condensor, tire pressure... well no, maybe not tire pressure. ;)
I don't know exactly how they rate an auxiliary cooler based on using it in conjunction with a factory one, since not all factory coolers are created equal. Some tranny coolers (i.e. old Mercedes) are separate units that look just like little radiators, using air to cool. Other tranny coolers are embedded into the bottom of the radiator, which is mostly cooled by water (since even hot radiator water is cooler than tranny oil.)
Since you have a line on a cooler of a workable size, and you're planning on installing a temp gauge anyway, I'd see if this unit is capable of keeping the temps where you want them. (That 175-195 figure seems a tad low, if it's degrees F-- recall that most trans gauges are higher ranges than most radiator gauges.) If it ends up being not sufficient, then go back to the drawing board and redesign, and sell the tranny cooler to a guy in a Toyota who's driving to Vegas.
I wouldn't normally recommend designing by trial and error, except that in this case it strikes me you're probably not very far off.
- Erik
PS. Yes, it will work a LOT better if you install it so that air flows through easily. That GVW rating goes out the window if you install it sideways, or under the passenger's floor or whatever.
PostPosted: Thu Nov 28, 2013 6:28 am
I plan on putting it behind that opening in the bumper. I will order a large one, and install a temp gauge. If it runs too cool, I can simply cover part of it. In my imagination, which is always easy to do, I can see a set of lovers that would control air flow through it. Blocking it all off when cold would enhance warm up.
This project gets more involved.
Sam
PostPosted: Thu Nov 28, 2013 4:48 pm
You could always get one of those oil thermostats............
PostPosted: Fri Nov 29, 2013 5:25 am
Tell me more please.
Sam
PostPosted: Fri Nov 29, 2013 2:19 pm
Something like this:
http://www.summitracing.com/parts/der-13011/overview/
(If you look around you could probably get a better deal....)
PostPosted: Fri Nov 29, 2013 3:08 pm
Thanks! That looks like a simpler solution to the problem. I am bookmarking that page. Now I will have a temp sender and a thermostatic control in the line.
Sam
PostPosted: Fri Nov 29, 2013 4:03 pm
Might as well use braided stainless hoses and AN fittings while your at it..........
:wink:
This one has a mounting bracket:
(don't think it has the nipples, but if you use AN fittings, you can't use them anyway)
http://www.summitracing.com/parts/der-25792/overview/
