It is currently Wed May 06, 2026 8:46 am
PostPosted: Fri Nov 29, 2013 5:21 pm
I've got a 77 B100 with a 225 and a 3 speed manual tranny.
Last week out of nowhere it started acting weird for seemingly no reason.
I'll drive about 2 miles then the van shakes violently when I give it gas, then if I keep giving it gas it will shut off, if I let the engine cool down it will start back up and I can limp it home.
at first I thought it was a carb problem, I checked and it was not.
then I replaced the coil, that wasn't it.
any ideas? my daily driver just crapped out so I have nothing to drive, and it's making me crazy.
any help will be greatly appreciated.
Twisty.
77 Tradesman 100
PostPosted: Fri Nov 29, 2013 6:41 pm
I would try changing the ignition control module,or as known as contol box
PostPosted: Fri Nov 29, 2013 7:40 pm
What did you do to eliminate a carb problem? Did the choke malfunction and not fully open?
What ignition is on it? Hopefully not lean burn / esc.
PostPosted: Fri Nov 29, 2013 8:51 pm
Sounds like water in the gas....happened to me the other day when I got a bad load of fuel. I poured some "Heat" - (Yellow bottle), down the air vent to the float bowl and let it do its job and rest in the tank.... cleared it right out with a couple of bangs..... I think the fuel must have changed to the winter blend and it's full of water. Too much ethanol...... I couldn't move forward much less back into my driveway....pretty pathetic! That was a few days a go ......since then it has stumbled a few more times and I poured some other ethanol treatment in the tank that is suppose to mix with the water.
PostPosted: Sat Nov 30, 2013 8:24 am
Check for vacuum leaks...and check the carb mounting bolts to the intake and make sure they are tight!
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Sun Dec 01, 2013 2:41 pm
Car Model: 1977 B100 Van
I have a ’77 B100 manual van too.
Had a somewhat comparable issue when I bought it: flat spot when giving it gas leaving from a stop. I had to do a bit of play with the clutch and gas pedals so I won’t stall at every light.
Problem was caused by a wrong year/missing parts carburetor which developed a vacuum leak and a blown distributor advance pod.
All the advices given here make sense. Vacuum leak, choke not working correctly or bad gas are quite easy to test individually. I hope you'll find the culprit soon.
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
