It is currently Sun Nov 15, 2026 6:37 am
 Post subject: trans gear ratio's
PostPosted: Tue Dec 10, 2013 3:00 pm
Car Model: 1966 Plymouth Valiant
i found a friend who has a stort tail od trans, it has a 3.09 first gear and it also has a 5" throw out bearing colar, is that all right for a /6 street car ? is the 3.09 too high of a first gear? can i use that colar on the throw out bearing? will it work in a street car? is it the right one to use?
 Post subject: Er...yeah!
PostPosted: Tue Dec 10, 2013 7:01 pm
Considering those trannies were used from 1975-1976 in A-bodies stock, and F-bodies from 1976-1980 for daily driving that should not be a problem.
All A-833 OD tranny come in:
1st gear 3.09
2nd gear 1.67
3rd gear 1:1 (direct and the collar locks the input to the mainshaft)
4th/OD gear .73
3.09 is not really too low for most street ratios, but will be a 'hiccup' on the way to 2nd gear for anything that is a 4.11 or 4.56+ rear ratio (in fact that tranny in my duster will accelerate itself off the line if I just let out the clutch in 1st).
What you will find is that the OD gear is a little "steep" if used with a 2.94 or 3.23 rear end...I found that a set of 3.55's are a good 'street' gear for it (fun off the line but you get to keep the gas mileage on the highway), I think a set of 3.73 or 3.91's would be about right for a hopped up street/strip car.
It will use the standard throwout bearing used on any road mopar with a 3 or 4 speed (except the trucks with the NP-435 4 speed).
:wink:
PostPosted: Tue Dec 10, 2013 7:11 pm
I had a cast iron version of that transmission in this Dart for awhile. I took it out and put it in my 360 Dart (now sold) when I went with the T-5. It was a good combo for the slant, but as DI says, there is a steep drop off going into 2nd. It might still be in this car if I had not been looking for an OD tranny that would hold up to the power of the 360. It is the easiest way to get an OD tranny behind a slant. It did not shift as fast as the T-5, but the 360 would have crushed this t-5.
Sam
 Post subject: gear raitos
PostPosted: Wed Dec 11, 2013 9:26 pm
thanks for the quick reply !
PostPosted: Thu Dec 12, 2013 10:59 am
Some info here:
http://www.slantsix.org/articles/4-spee ... speed1.htm
 Post subject: transmission
PostPosted: Thu Dec 12, 2013 12:05 pm
thank you for your help!!!
