It is currently Tue Sep 22, 2026 9:42 am
 Post subject: Can you ID this 904 LU?
PostPosted: Sun Dec 15, 2013 6:29 am
Here are some photos of the trans I purchased. Can anyone ID it for sure as to year and application? Thanks.
I have more photos if you need to see another angle.
Thanks. Sam
PostPosted: Sun Dec 15, 2013 8:20 am
Sam- here is a web page listing all the Mopar transition part numbers from 65 to 86.
http://www.mymopar.com/downloads/transguide.pdf
I couldn't find your number on that list, so I believe you are right that it is some kind of factory remanufactured unit for replacement.
The number on your pan rail appears to be
PK1327658312777
with the "P" overstamped by a "4".
The closest match I could find for the number on your pan rail is
4058311
which is a 1979 standard duty truck two wheel drive slant six 904 with a long extension housing. That makes sense since your tailshaft housing looks a bit long to me But it could just be the angle of the picture.
That is the best I can do for you. Maybe someone with better reference books can offer a better answer.
PostPosted: Sun Dec 15, 2013 1:27 pm
From Torque flite transmission field servive information book.From chrysler service training. 4058311 is long extension lockup A-727. 1979 225.
PostPosted: Sun Dec 15, 2013 1:30 pm
5831 is date code http://maxwedge.com/articles/10k.php
PostPosted: Sun Dec 15, 2013 1:34 pm
The pan is shaped like a 904, so I am not sure how they would classify this as a 727. Did they beef up a 904 and call it a 727? I have heard the 727 used more horse power? Is this true, and if so why? Does anybody think this is a 727?
The tail shaft housing is 15" long to the end of the housing, not counting the seal. The trans mount is 7" back from the joint between the housing and the main case.
PostPosted: Sun Dec 15, 2013 1:37 pm
torqeflite id discussion http://maxwedge.com/articles/10k.php
PostPosted: Sun Dec 15, 2013 1:52 pm
Thanks for all the help. YOu guys are responding more quickly than I can look at the info and respond. I am always about one post behind. Please look back up above here.
Date code calculator says this trans was made on July 15th 1977. It must have been for '78 production. If that number 58312 is the date code, what numbers on the tranny would correspond to the model ID chart in Reed's link. Things are not making much sense with the rest of the numbers.
Thanks. Sam
PostPosted: Sun Dec 15, 2013 2:00 pm
2777 is seqence no. 2,777 built that day Date code 5831 works out to July 15 1977. Looks to me like your orignal numbers have been filed off. An orignal number starts with a faint P K then seven numbers. For exsample PK4058383. then space date code xxxx space sequence no. Some times on other side of tranny on bell housing is a partial vin no.
PostPosted: Sun Dec 15, 2013 2:20 pm
Looks like 904. 4058311 is a good tranny number. Its Just not for the one you have. 5831 is the date code.
PostPosted: Sun Dec 15, 2013 3:01 pm
The spotting guides I found on line have this as a standard 904 for a passenger car based on the tabs below the tail housing between the speedo housing and the cross member mount.Does anybody know what those tabs are for? The length agrees with what I found on line for what they identify as a 904, but they did not specify short or long tail. They said 904. Distance from mount to tail shaft end is 8 inches as indicated on the drawing I found on line.
I also ID'd it as a lock up based on the number of spline (26) on the input shaft. So what I know so far is that it is for a car, it is a 904 and it is lockup. But I do not know the year. The story unfolds.
Thanks for all your help.
Sam
PostPosted: Sun Dec 15, 2013 3:05 pm
Input shaft spline count. Lockup has 26 teeth ,non-lockup has 27 teeth.
PostPosted: Sun Dec 15, 2013 5:31 pm
It does have 26 teeth.
Sam
PostPosted: Sun Dec 15, 2013 5:59 pm
6 Pack Dart
That is where the floor shifter bracket bolts on.
Richard
PostPosted: Sun Dec 15, 2013 7:10 pm
Man, I missed the boat completely on that one! Good thing I only rarely try to ID a part by the part number.
PostPosted: Mon Dec 16, 2013 4:48 am
That is what the tabs look like. Does anybody know the distance from mount to end on the short and long tail shafts? This is 8" not counting the seal, which sticks out another inch or so.
Don't feel bad Reed. This is murky territory. Someone on all par said those numbers "don't tell you squat". Apparently he had been fooled a few times before. I trust the date code, but nothing else there.
Sam
Users browsing this forum: DuckDuckGo [Bot] and 9 guests
