It is currently Sun Nov 29, 2026 7:05 pm
 Post subject: 8.75 rear
PostPosted: Thu Jan 08, 2004 3:43 pm
Did ma MOPAR ever put LBP 8.75 axles in A-bodies or any thing else for that matter?
PostPosted: Thu Jan 08, 2004 3:58 pm
Yeah, one time. The '68 Hemi Dart and Barracudas with automatic trans. A total of approx 150 were made, about half had auto trans and the LBP 8.75 A body axles.
Cecil
PostPosted: Thu Jan 08, 2004 4:03 pm
How would you tell?? Cause I have a 8-3/4 posi rear with 3.55's. It will fit perfectly into my 66 dart.
Hellbent Rods & Custom fabs
PostPosted: Thu Jan 08, 2004 4:16 pm
Ok thanks for the info. my brother-in-law has an 8.75 he wants to put into his 70 baracuda convertable and dosent want to go to SBP. he found somewhere he can get axle shafts for his rear that are LBP though. He was just wondering if there might be actual stockers.
PostPosted: Thu Jan 08, 2004 4:28 pm
A 70 Barracuda in not an "A" body. It is a "E" body, which has a wider rear than an "A" body. As far as I know only the "A" body 8 3/4 rears had the small 4 inch bolt pattern, all othe 8 3/4 rears had the 4 1/2 pattern.
PostPosted: Thu Jan 08, 2004 8:15 pm
Find an 8 3/4 from a B body to fit under an E body. The E body was based on the B body, so the rear width should be the same. No, he can't have mine.:mrgreen:
PostPosted: Fri Jan 09, 2004 5:17 am
He actually bought it to put under his featherduster, but found out that his 15 inch ralleys with I think 275/60R15's fit under the barracuda so now he wants to put the 8.75 under there.
so the rear he has is likely to small for the barracuda?
PostPosted: Fri Jan 09, 2004 8:07 pm
The E-body rears are actually wider than a B. :shock:
PostPosted: Sat Jan 10, 2004 12:04 am
Really? I thought at least the '71-'72 B body 8.75's would fit as they were a little wider than the pre '71's....:?: How about a C body unit?
 Post subject: Rehash the axle issue...
PostPosted: Sat Jan 10, 2004 9:19 am
A-body backing plate to backing plate: 51.4" (shorter axle shafts on pre-73's...).
8 1/4"/ 9.25" B-body 57.8"
8 1/4"/ 9.25" C-body 59.2"
8 1/4" F-body 54.34"
1962-1970 B-body 8 3/4":55"
1971+ B-body 8 3/4":57.8"
E-body (all): 56.5"
not responsible for any typos....
PostPosted: Sat Jan 10, 2004 11:13 am
Wasn't the '70 Roadrunner tha last real B-body? :twisted: :twisted: :D
PostPosted: Sat Jan 10, 2004 12:45 pm
You mean I have a fake one? :shock:
PostPosted: Sat Jan 10, 2004 4:11 pm
Ok he has an 8.75 under the Barracuda now and is thinking of putting his 3.91 gears in it instead of putting them in the 8.75 that he bought for the feather. he also has a set of 3.55s and all three centers he has are sure grip units. that guy finds so much cool stuff is isnt fair. Also a complete 8.75 w/ 3.23's and a sure grip go for around $500 around here
PostPosted: Sat Jan 10, 2004 7:42 pm
Sucks, don't it? :twisted: :D :lol: :twisted: :shock:
PostPosted: Wed Jan 14, 2004 8:18 pm
:o where did you got the electric fan? I mean, from what car? I'm looking for one thin unit like you have installed. Thanks! :wink:
