It is currently Sat Nov 28, 2026 12:21 pm
PostPosted: Wed Nov 13, 2013 7:54 pm
when I added the wiring for the additional gauges, relays,cruse control,,, on the D150 in passing through the firewall I ran the wire through grometed holes
I want to go back through the wiring this winter and add robustness and servicability to the wiring changes.
I want to change the firewall pass through from the unbroken wire to a bulkhead connector.
this one looks promising...
http://www.eficonnection.com/eficonnect ... ItemId=762
everything is bought a la cart,,,
a male and a female connector, latches, terminals and seals, come to roughly 70.00
this looks to be OEM quality stuff, but does anyone have alternatives?
here is the page with all the conectors they offer..click the search button
http://www.eficonnection.com/eficonnect ... earch.aspx
PostPosted: Thu Nov 14, 2013 4:08 am
Contributor
I've been looking for a connector like that, and the quality looks good...thanks for posting!
PostPosted: Thu Nov 14, 2013 4:52 am
the quallity does look good,appears that EFI has figured out how to buy from an OEM supplier and is re packageing for sale in small quantities.
They are just a bit pricy.
PostPosted: Tue Nov 19, 2013 11:30 am
found a less expensive bulkhead connector option at Americal Autowire, as well as lot of other nice wiring ideas..
http://www.americanautowire.com/shop/american-autowire/
found the firewall connector for even less at Sumitt
http://www.summitracing.com/parts/aww-500666/overview/
PostPosted: Tue Nov 19, 2013 1:03 pm
Dan Stern gave me a lead on this connector from DIY Autotune.
Weather Pack 22 position bulkhead connector kit
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
PostPosted: Tue Nov 19, 2013 4:03 pm
looks to be the same connector for less $
thanks
PostPosted: Thu Dec 19, 2013 8:25 am
This looks like same item on ebay little cheaper
http://www.ebay.com/itm/22-Cavity-Weath ... 0918783448
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Fri Dec 20, 2013 10:45 am
I bought one of the weather pac 22 cavity fire wall coupling,,for the price,,
well made, nice weather proof perimeter seal,, only down side is that it is sized to accept the 240 series pins,, and those are rated for 20 amp service,, good for many automotive circuits,, but not all,,
the Delphi connector shown in the first post accepts 280 series connectors (30 amp rating) and has 6 openings for 480 series (42 amp rating) connectors.
I can make the weather pac 22 work for this project, next time I am getting the Dephi connector
PostPosted: Fri Dec 20, 2013 12:15 pm
Car Model: '23 T-bucket
Dadtruck....perhaps you should keep the higher amperage loads out of the passenger compartment, and run relays through the smaller amperage pins. Fuse the load wires, run them through the relay contacts, then on to the load. Control the relay(s) with switches from the driver's seat.
Roger
PostPosted: Fri Dec 20, 2013 2:04 pm
agree that the 240 series connectors would be fine for signal connections. Relays for: HEI, electric fuel pump, high and low beams, electric radiator fan, high mount stop light are all on under hood relays,, a signal connection would not fit in with the ac/ heater blower wiring ,, the blower resistor on the D-150 mounts into the front cowl, accessable from the dash side of the firewall, the blower motor that is fed from the blower resistor is on the engine side of the fire wall, for that one I got a length of 10 gauge wire and ran a continious wire from the resistor to the motor,, insulated the wire where it goes through the fire wall with convoluted tubing and a hard nylon gromet
PostPosted: Fri Dec 20, 2013 4:33 pm
You are absolutely right.....I didn't think about that one, sorry. :oops:
Roger
PostPosted: Sat Dec 21, 2013 3:09 pm
Could the blower resistor be relocated under the hood?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Sat Dec 21, 2013 4:55 pm
yep, or just get a firewall plug with more substantial connectors...
PostPosted: Sun Dec 22, 2013 3:09 pm
How many additional wires do you have to run thru the firwall?
I know when I rewired my 86 2 years ago there were quite a few open cavities on the OEM bulk head connector.
Could you possibly run them thru there?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Thu Dec 26, 2013 7:45 am
xjarhead,,
, my oe 83 firewall connector has 10 open cavities,,
have you found a source for the oe connectors and tabs? That was one reason why I did not go that route, the other is that there is a mass of wires there already, since on my 83 there is a mix of oe and new circuits, for future trouble shooting I wanted to keep them separate.
thanks
