It is currently Tue Nov 24, 2026 5:23 am
PostPosted: Fri Dec 27, 2013 6:38 am
/6 rod style 1920, i can't see anyplace for return spring to go on carb linkage ? surely has to be top end near the 2 screws.? but no little hole or slot for it. couldn't find any help under search.
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Fri Dec 27, 2013 8:34 am
Car Model: 1964 Valiant V200
It goes in the middle of the rod, down to a tab that is under one of the starter bolts.
 Post subject: spring
PostPosted: Fri Dec 27, 2013 9:59 am
the spring i'm referring to is the spring at the carb throttle. ??
PostPosted: Fri Dec 27, 2013 4:41 pm
O K carb has no spring , just the one at the rod. i adjusted the rod at gas pedal and all works great now!!!
