It is currently Fri Jul 17, 2026 2:33 am
PostPosted: Fri Dec 27, 2013 9:32 pm
Site Admin
OK, so I've been talking to various racers about the diameter of the OP drive gear shaft. We're trying to find a happy spot for an interference gear.
I measured the Melling pump I picked up from a group buy a few years ago.
It measured .4850" with my dial calipers. I decided that I needed to be a bit more accurate to make sure. I broke out my micrometers, calibrated them to the appropiate standard, and got .4850" which makes me feel really good about my dial calipers! :lol:
The .500 gear from a distributor will not work.
What is the small diameter gear for the SBC? how many teeth, and what diameter is the gear hobbed on? There is a smaller diameter shaft size for that gear. I'm wondering if we can use that bronze gear for oil pumps on billet cams...
CJ
PostPosted: Sat Dec 28, 2013 2:31 am
Somewhere in my treasures I have a bronze gear for a Slant oil pump. I think the Cox Bros. had them made.
PostPosted: Sat Dec 28, 2013 6:43 am
When it gets light I will see if I have a SBC oil pump near the top of the pile.
If not this morning ....I will check after my ski lesson with my 3 yearold grand daughter,,,,
PostPosted: Sat Dec 28, 2013 8:18 am
LMAO/////of course its the dist drive gear on a SBC,,,,
The small shaft size is .491.
PostPosted: Sat Dec 28, 2013 8:26 am
The outside dia of the gear is ~1 3/16.....it has 13 teeth
Measured and counted on a 7 pin EFI dist (as far as I know they are all the same)
PostPosted: Sat Dec 28, 2013 8:30 am
Crower makes a .427 shaft size gear
http://www.summitracing.com/int/parts/c ... /chevrolet
PostPosted: Sat Dec 28, 2013 2:47 pm
I have no idea if this gear is even close
but mopar part number p3690874 has a bronze gear
http://www.jegs.com/i/Mopar+Performance ... 4/10002/-1
