It is currently Mon Jun 15, 2026 1:15 am
Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sat Jan 04, 2014 2:04 pm
I had a good day, I also scored from same car ( 75 Dart ) what I believe will be everything I will need to convert to electronic ignition.
I believe I took everything that was there, was surprised at what little there was once I opened up the harness.
Are the Mopar brains still avail? This is a knock-off and I am assuming I should find a better quality part?
Ill have more questions prob. on this but again this will be a project for down the road.
PostPosted: Sat Jan 04, 2014 2:09 pm
I also scored the heat riser deal, I was wondering what the little bracket was that is attached onto my manifolds, now I know it is too attach this collector. Image
As you can see I also learned that the 75 Dart ( at least ) used a vacuum fitting for the lines that was not made from pot metal, came off easily and will replace that Ford unit I found.
I am assuming that the breather will work on my valve cover? Do these need to be cleaned and if so how.....I also want to find an earlier ribbed valve cover, I dont like the one on there, plainjane.
Will the earlier covers bolt onto my later engine no problem?
PostPosted: Sat Jan 04, 2014 2:11 pm
I got the air cleaner while there Image
PostPosted: Sat Jan 04, 2014 2:13 pm
I also found this carb at a different yard this A.M. Removed from a 78 Volare or Aspen, not sure.
Crusty but I figured at the time it might have been my only option, finding these cars and their parts are tough around here.
I am assuming at this point I am better off with the previous carb pictured?
PostPosted: Sat Jan 04, 2014 2:50 pm
I found this diagram on-line, assuming this is the correct 1975 carb than it would appear this is the vacuum diagram I would need.
I will post this here cause I am sure it might interest someone else and I am sure I will have more questions and it will all be in one place
PostPosted: Sat Jan 04, 2014 3:19 pm
You did good!
And yes MOPAR ECU's are still available anywhere...that isn't a problem. You should always carry a spare ECU and a spare voltage regulator.
Those air cleaners aren't cheap anymore either....good one!
Good diagram!
Congrats!
PostPosted: Sun Jan 05, 2014 2:14 am
You did good!
Good diagram!
Congrats!
Thanks very much
 Post subject: Did?
PostPosted: Sun Jan 05, 2014 8:23 am
did that engine have a distributor in it? If so you might go back and check and see what number it had on the tag....if 3874876, you might be able to use it for a recurve or sell it here for some project $.
:wink:
 Post subject: Re: Did?
PostPosted: Sun Jan 05, 2014 10:05 am
:wink:
Its about an hour away but I will check it out the next time I am there
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
