It is currently Mon Nov 23, 2026 9:13 am
 Post subject: Oil breather
PostPosted: Sun Jan 05, 2014 4:34 am
I am hoping to be able to use this earlier air breather on my later engine. Cleaning it out with brake cleaner is all I have done in the past. Do you guys agree with this? Do these things ever go bad?
PostPosted: Sun Jan 05, 2014 6:08 am
I think it is just a can filled with expanded metal gauze with two openings. Cleaning in solvent of some type should work well.
PostPosted: Sun Jan 05, 2014 8:13 am
Great, thanks
 Post subject: Yep...
PostPosted: Sun Jan 05, 2014 8:21 am
Dropping it into a small metal bucket full of xylene or Tolulene for a few day soak will soften up the crud, then hose it out in a part cleaner if you have one.
 Post subject: Re: Yep...
PostPosted: Sun Jan 05, 2014 10:06 am
Dropping it into a small metal bucket full of xylene or Tolulene for a few dya soak will soften up the crud, then hose it out in a part cleaner if you have one.
Will do
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 2 guests
