It is currently Sun Nov 22, 2026 11:55 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
 Post subject: Ok
PostPosted: Tue Jan 07, 2014 9:30 pm
I see, and if the Y to the single doesn't sacrifice power, then why run duals?
Makes sense...
Is there any math behind how long your downpipes run before going into the Y with regard to power, noise or anything else? I've seen the Y pretty close to the dual manifolds and as far back as past the tranny...what's the logic there? I think space is an issue near the tranny, but otherwise is there any gain from closer or further from the manifolds for the Y?
brian
PostPosted: Wed Jan 08, 2014 7:12 am
My true dual setup sounded awesome at idle and cruising at 60+ mph, but the drone at certain mid-range rpms was absolutely horrible....
This is where the Flow Master HP2's really shine when installed in front of a FM70 or a conventional muffler. They eliminate all that horrible resonance. My system is super quiet and it's 2.5". Performance increase is very good and strong on a tired stock motor.
