It is currently Wed Nov 25, 2026 9:12 am
PostPosted: Fri Jan 10, 2014 10:47 am
Car Model: 1962 Valiant V-200
I've had no luck whatsoever trying to source a new roller bearing for the steering shaft of my '62 Valiant. The '62 Val has only one steering shaft bearing in the steering column, and it is up near the top, under the turn signal switch. I have not been able to find the Chrysler part number for this bearing. It has an OD of 1-3/16" (1.1875"), an ID of 3/4" and it is 1/4" thick.
It seems like it would be a common small bearing, but I can't seem to find one. Frank Mitchell say she has one for $50, but I just don't know about that guy. Can anybody help me find this part? Thanks a lot!
PostPosted: Wed Jan 29, 2014 9:13 am
have you tried FFI? best on the market. in vancouver, WA.
http://www.firmfeel.com/
PostPosted: Wed Jan 29, 2014 2:22 pm
Are there any close metric bearings?
With this application, you can always use shims to make something close work.....
