It is currently Mon Nov 16, 2026 7:30 pm
PostPosted: Mon Jan 13, 2014 9:42 pm
Looking for a shifter to install in my 64 valiant. The trans is an A904 from a 73 duster.
Cutting a hole in the floor and fabbing brackets are fine. I looked at the lokar shifters and they sure look nice but out of the budget. Nothing fancey or racey. JUST need to select gears to drive down the road. What are you guys using.
PostPosted: Tue Jan 14, 2014 3:55 pm
I use the B&M unimatic
http://www.summitracing.com/parts/bmm-80775/overview/
PostPosted: Tue Jan 14, 2014 4:08 pm
If you're bucks-down get the shifter and linkage from a Dodge D50/Plymouth Arrow. They use the baby 904 and will do the job well if you can find one.
PostPosted: Thu Jan 16, 2014 8:28 am
I saw a used B&M ZGate on Moparts.com it may still be there.
