It is currently Tue May 19, 2026 5:42 pm
 Post subject: slant six brackets
PostPosted: Tue Jan 14, 2014 2:58 am
Can someone here confirm these brackets are the factory parts needed to make the super six set-up work on my truck. I only have ( actually still waiting too arrive ) the intake/exhaust manifold, carb and air cleaner at this point.
I have a manual trans. I can see the kickdown in the picture for the automatic, was there a different bracket for manual trans that did not have the extra provision for manual trans vehicle?
Thanks
 Post subject: Yep...
PostPosted: Tue Jan 14, 2014 6:26 am
The bracket is different, but manual super sixes are as rare as original hemi's, I can say in the car application, the auto bracket into a manual car acc. pedal application work fine just remove the kickdown pivot and your install will be complete.
 Post subject: Re: Yep...
PostPosted: Tue Jan 14, 2014 11:23 am
Ok thanks, now to find one
PostPosted: Tue Jan 14, 2014 11:34 am
to adapt a Holley 2280,, I used late 70's v8 mopar throttle cable,,
may have been off a Mirada?
much shorter than the OE 1983 D-150 cable and fit fine.
PostPosted: Tue Jan 14, 2014 3:33 pm
Ok I was not aware that a throttle cable needed to be changed as well?
 Post subject: Yep.
PostPosted: Tue Jan 14, 2014 3:38 pm
On the cars the throttle cable is short like the 318/360 acc. cable... looks like that holds up as well for trucks....
PostPosted: Tue Jan 14, 2014 4:48 pm
Ok will check it out after I get the linkage parts, thanks
PostPosted: Wed Jan 15, 2014 2:41 am
Somebody offered me this linkage ( for a price ) it is different than what I have already pictured. They say Super six linkage, surely there could not have been more than one version or maybe there was a truck and auto?
