It is currently Sat Nov 14, 2026 3:47 am
PostPosted: Mon Jan 13, 2014 9:59 pm
read through the forum on this subject of efi
some were posted years ago
just need to know what EFI for slant6 setups are is currently available
a supplier for all parts to contact
spose will get prices form him
thanks
 Post subject: Slant six EFi
PostPosted: Fri Jan 17, 2014 8:24 am
There is a tone of stuff, you just have to look. You can follow the really great tech article from Bob DiBase http://www.slantsix.org/articles/dibias ... ersion.htm
You could use a TBI kit from FAST http://www.fuelairspark.com/fas/ You can purchased matched fuel injectors. http://www.doctorinjector.net/7343.html
What are you looking for?
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
 Post subject: Diy
PostPosted: Fri Jan 17, 2014 2:00 pm
there are no "plug and play kits", you basically just get the parts from a manufacturer and do it yourself.
 Post subject: Re: Diy
PostPosted: Wed Jan 22, 2014 11:26 am
Some of the TBI setups may be drop on, but I'm not sure how well they do on fuel distribution.
Clifford did make a couple ready to go EFI manifolds, but there wasn't much demand for them and they stopped building them. (And they aren't the easiest outfit to order from, either).
A while ago, I tried to mentally piece out what a bolt on kit might look like with off the shelf parts from a number of sources:
http://www.slantsix.org/forum/viewtopic ... highlight=
Such a setup would use Extrudabody throttle bodies on a Pierce manifold intended for Weber DCOEs. A couple of the parts I had listed are no longer available or have gone up in price a little.
Or you could have a machine shop rework a four barrel intake manifold - that's what I did.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
