It is currently Mon May 11, 2026 8:28 am
 Post subject: LCA Interchangeability
PostPosted: Thu Jan 23, 2014 9:15 pm
I have a 74 dart with 225 and 9" drum brakes. I'm looking to pickup some junkyard LCA's so I can have the bushings pressed in/out in advance. Is the LCA different between Disc and drums or am I safe getting LCA's off a disc brake car?
PostPosted: Thu Jan 23, 2014 9:44 pm
Your safe as far as drums/discs. The only possible difference is the stock sway bar mounts changed when going to bbp. If your not using a stock sway bar your fine.
PostPosted: Fri Jan 24, 2014 10:09 am
So, to be clear, the lower ball joint connection point is identical?
PostPosted: Fri Jan 24, 2014 10:57 am
Yes, it is.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
Users browsing this forum: Bing [Bot] and 14 guests
