It is currently Sun Nov 22, 2026 12:41 pm
 Post subject: Alternator
PostPosted: Sat Feb 01, 2014 5:34 am
I am wondering if there is either a different alt I can purchase or a better designed set of brackets avail to mount my alt. Problem is removing the # 1 plug, its a pain in the knads cause its hidden behind the alt. I can get the socket on it without touching the alt but again its just not easy.
Any suggestions?
PostPosted: Sat Feb 01, 2014 5:38 am
If you have the room on the D/S that is a great option and really opens up the passengers side to get to everything.
PostPosted: Sat Feb 01, 2014 7:20 am
Also may try the smaller style alternator and a little longer belt to move it out just a bit.
Rick
PostPosted: Sat Feb 01, 2014 7:48 am
I dont think there would be room on D.S, A/C compressor and power steering pump on that side, smaller alt? Have any more info on that?
PostPosted: Sat Feb 01, 2014 12:17 pm
Go with the Denso alternator mod....
PostPosted: Sat Feb 01, 2014 6:55 pm
try using a universal joint on your socket and extension; works fine reaching in behind my seventies vintage square back alternator.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
