It is currently Mon Nov 23, 2026 2:19 am
PostPosted: Tue Feb 04, 2014 10:12 pm
I had no luck with the timing change so its back to where it was. So I hooked up the timing light. I tune the carb to 750 in N w/hi-beams on and adjusted the A/F ratio. So I take the car for a test drive and I find out after getting back and rechecking it that it is now idling at 680 in N w/hi-beams on. I readjust and cycle through the gears and it idles a 817 when the car never moved and I went from P to 1st and stopped in N. I readjust and The idle drops to 728 and I go to where the idle Speed screw was when it was 817 and it goes to 755. I let it idle and it goes from 755 to 746 to 756 to 768 and it bounces from 738 to 770 and never returns to 750. I think it may be time for a carb rebuild.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
 Post subject: idle...
PostPosted: Wed Feb 05, 2014 10:39 am
Did you check to see if the throttle shaft that opens and closes the butterflys is lubricated and rotating freely?
PostPosted: Wed Feb 05, 2014 3:51 pm
Yes. It is :)
