It is currently Sun Nov 22, 2026 6:26 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Thu Jan 15, 2004 6:16 pm
SSRN National Champion
This tip came from a racing legend im not a legend but the person who gave me this tip is. Ron Parker
PostPosted: Fri Jan 16, 2004 7:03 am
Josh
With holes that small the fiberglass cloth would work fine, be quick and last a long time. POR 15 makes some good products but they can cost a little more.
Their website is www.por15.com , look for putties and filler page.
Also just in case you did not realize it you should remove the tape from the backside after whatever you use has hardened. :shock: You are only using this to provided support when you apply the material.
Bob
